- 29 Apr 2010
Ok I have brought 2 of the following and I am running these as RAID0 I tried as RAID1 so that I don't loose any data if a drive fails, but due to the drives was even slower than my old Hitachi 500GB 3Gbs drives I thought id try them as RAID0 as type AHCI.
These are fitted to a Gigabyte GA-X58A-UD3R board which has 6 Crucial Ballistix 6GB (3x2GB) + 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) using XMP (Profile1) giving me a total of 12GB.
I am also using an i7 920 D0 @ 2.667GHz + Turbo (2.8GHz) which all seems fine apart from the HDD speeds, which is my bottle neck in my system.
As RAID0 they perform a lot faster I mean at least up to 4 times faster when they was in RAID1.
I am still not too sure that these drives are running at their proper speeds, sure I know there are limitations with mechanical drives but if it says that they are 6Gb/s drives they should do it, if they don't they shouldn't be sold as a 6Gb/s drive.
Anyway here are my test results using ATTO and HT Tune using default settings:
*** Updated ***
As you can see I am only getting about 1.76Gb/s come on, how can these be sold as 6Gb/s drives when they dont even get over 2Gb/s ?
Now I know why they don't say their transfer rate in their specs.
Atleast with SSD drives they state that they can reach upto X transfer rate when reading and when writting, that way you know what you could get upto, but this doesn't seem to be the case with mechanical drive.
Mindyou even the SSD don't reach the 6Gb/s the most i have seen people post over the internet was approx 550MB/s thats just over 4.6Gb/s (not bad) but these drives where also as RAID so if you half that, thats 225MB (2.3Gb/s) per SSD and these are also badged as a 6Gb SSD.
Also there is a limit of the speed of the controller interface and with this board its says in my BIOS that its max Transfer rate is 5.0Gb/s which is prob why people get a max of around 4.6Gb I guess.
So if I double that for using RAID0 I should get approx 250MB/s MAX thats about 2Gb/s.
I still think these should be badged as SATA2 3Gb/s drives.
Oh and yes I have them connected to the Marvell 6Gb sockets and I have the latest drivers installed.
Is this the best that I am going to get from these Drives on this Board?
I think I was getting better on my RAID5 system (a couple of years back) that used 6+ 500GB drives in it.
But where I wanted to cut down on the drives to let more air into my case I reduced them to 3 drives (2 6Gb drives as RAID0 and 1 normal 3Gb drive)
Any help would be nice
Thanks in advance
Paul
*** Update ***
Silly me, i should have checked WD site first /me slaps face.
Data Transfer Rate (Buffer to Host) 6.0 Gb/s
Data Transfer Rate (To/From Disk - Sustained) 126 MB/s
Still anyway to squeeze the extra MB out of it?
*** Updated ***
Thanks in advance
Paul
*** Update ***
) I went back to a couple older drives raided and damn if it isn't slow as hell. But the most important thing, even things like access OTHER mechanical drives is far slower. Things like processing and loading thumbnails and listing a folder contents, from another mechanical drive, takes hugely longer, not just loading apps/games off the SSD but everything you do on any drive is sped up by having Windows on a SSD.
The most common port multipliers are silicon image (aka Steelvine) and the cards that can talk to them are about £8 each from the far-east.
