My Lian Li PC-A71F
^ very nice, ive noticed though that on the A7IF, the pwr/reset/hdd led cable seems to be a flat stamped cable, whereas on my A70F theyre individual plaited cables per connector.
THAT CASE IS HUAGEEE.
very neat build.
Didn't know blu-ray came in ide, thought ide was far to slow to run blu-ray movies.
wow very nice job jej !
so much space in there, that 5870 will soon get lonely on its own
good job done my friend
Built myself one of these recently and I'm very happy with it. I was so tired of taking my knuckles off every time I tried to do anything in the mini tower cases.
The lian-li has acres of room for anything your heart desires, and should last me a good few years (until something else shiny catches my eye)
I'm quite proud of my wiring and braiding, must take some better pictures though.
How easy is it to swap out the front fans on one of these cases? do you have to remove the door and then the front bezal?
Yes, and to clean the filters on the ones with doors, the ones without have removable filters.
My only criticisms of this case are the above, and the fact that the motherboard tray isn't removable, but I still love it to bits despite those few flaws.
Do you have it on all the time with the front open? Otherwise surely that's going to be restricting the airflow a fair amount?
here is a picture of mine up and running now!
i had no problem with cable management and the only thing i did have to buy was 2 long sata cables to reach the optical drive and the ssd
Two very nice tidy systems guys. The room in theese cases is fantastic. So much easier to assemble a system in.
