You are concerned about doing damage as a result of not having oil temperature.
Correct. This was my second question after Bear said that his oil gets up to temp in around 5 miles at 70mph. My FIRST question was how long it generally takes to warm up the engine oil.
What does it matter how long it takes, your journey is over in 4 miles.
No it's not? And what do you mean "what does it matter how long it takes"?! Let's just assume that i love learning about oil.
You have clarified you are not considering leaving it idling to warm up on the driveway so unless you plan to reduce your speed (and your RPM) on your way there what else did you plan to achieve?
That
was the other option. I can either go via the fast NSL road or through 40mph limits. Not that this should even bother you because my route home isn't what i was asking about?
All you need to know is you are not doing damage as long as you are driving within reason.
All i need to know? I'm really not sure how i can be more clear on this, so i'm going to try a combination of bold, italic and capital letters - let's see if it works this time:
I AM INTERESTED IN ROUGHLY HOW LONG THE OIL TAKES TO WARM UP.
Did it work??
EDIT: Sorry i can't keep up with your edits - you must be bored.
And yes, what you drive matters.
*sigh* i'm well aware that it matters. But i said that i'm willing to bet that it wouldn't make a massive difference.
Why post a thread looking for affirmation and make a convoluted deal out of something that just does not matter assuming you're not being an idiot.
Affirmation? How can i look for affirmation....when i'm asking a question which i don't know the answer to?
FOR THE BENEFIT OF SIN CHASE:
PLEASE STATE HOW LONG (ROUGHLY) YOU CAR TAKES TO WARM IT'S OIL UP. IT HAS BEEN POINTED OUT THAT THE FOLLOWING IS ALSO REQUIRED:
-CAR MAKE
-CAR MODEL
-OIL GRADE
-NORMAL DRIVING OR FAST DRIVING
-HOW MUCH YOU WEIGH
-WHAT YOU HAD FOR BREAKFAST
-IF YOU HAD MILK ON YOUR CEREAL
-LONG HAIR?
APPARENTLY, ONLY AFTER YOU PROVIDE ALL THESE DETAILS CAN YOU ACCURATELY CALCULATE HOW LONG YOUR OIL TAKES TO WARM.
