- 5 Apr 2008
Whether the PC is watercooled or not will make no difference to room temperatures! Just dangle the radiator out of the window.
Yes i understand that.. just wanted people to picture the situation
If you are in to water cooling the pc then treat the heat in your room in the same way![]()
My gaming pc is watercooled and my bedroom is small... the window is wide open and even in the winter it gets insanely hot in here.. what more can i do?
I'll be watercooling my head tonight.
In jest? I think not. Think about the opposite of a hot water bottle and you will be on the right track.![]()
How hot is your room tho? i live in attic and its 35 degree and its 21:55 :/
Turn the PC off, go outside, get some sunshine.
Ummm, take a look out of the window - the sun went in a couple of hours ago.![]()
