GPS Mounts
Godfather
Godfather
17 Oct 2002
Bromsgrove
What kind of mounts are people using for GPS?
If you are looking for something really neat you could do a lot worse than the Techmount Stem Mount.
I bought one for my Zumo 660 and it positions the unit in just the right place. It's neat too. Here's a pic without the Zumo.
You can order it with the correct baseplate fitted for the 660. Quality is superb and there's a UK supplier. Recommended.
Here's another angle of the Techmount stem mount, with a bit of background interest ;)
http://img34.imageshack.us/img34/6498/mg0248h.jpg[img][/QUOTE]
That Tachmount stem looks rather tidy. How easy is it to remove? I've just got a ball joint on the top of my yoke that I can attach my TomTom too via a socket arm thing. Means it's quite tidy when I don't want/need the GPS.
Dead easy - you just pull it out.
Of course you still have the GPS wiring to deal with.
Any excuse for a bit Ferrari displaying LOL.
As for Velcro there's some pretty crazy strong stuff out there that I would use if you cant bolt it on. you would be surprised how strong some of them are
hmmmm, wanted something a bit more sturdy to be honest, would always have that constant worry it could fly off and cause an accident.
Duct Tape :p. That's how I had my GPS mounted for a while while I was waiting for my yoke fitting to come hah.
Anyways never mind gps. What happened to a map and a layby.
I have the uncanny ability to look at a map and just go there without having to look at it again.
Used to drive a van for a company and they named me the Pigeon because of it LOL
I have the uncanny ability of getting lost when leaving my close!, seriously, am bloody useless, I have no sense of direction and wouldnt get anywhere in the car without my sat nav.
hmm, both the fork and stem versions have been on back order for some time now :(
Tank bag may be the only solution unless I can find another UK supplier
