mountainmods Extended Ascension 28 fans help
I don't see the point he won't use half the power of the PC, it will be worth 1/10th as much in 6 months time and be outperformed by mid-range hardware in considerably less than 2 years.
Theres absolutely no point buying the biggest and best hardware any more, either buy something that matches your needs or the stuff that one step below as you generally pay closer to half the price and won't notice the performance difference.
+1
You've specced a system that would use upwards of 1500w (probably closer to 2,000 with all those fans and HDDs), on a 1000w PSU.
Apart from that, 4 of the fastest single GPUs running on a single 23" screen? It's pointless, rendering or not.
OK so the case is not for me then I will moslikly get this case
Lian Li PC-P80R ATI Special Edition Alu Case Red
thanks for all your help
can I ask which is best the
Sapphire ATI Radeon HD 5970 Toxic 4096MB GDDR5 Graphics Card
or
GeForce GTX 480
can the Sapphire ATI Radeon HD 5970 Toxic 4096MB GDDR5 Graphics Card be put in crossfire????????????
also anyidea when ati will 3d vision like nvidia any idea?
I think you need to sit and read a few reviews and benchmarks.
People are honestly trying to give you the best advice here, I suggest you read this, and then with the spare cash, take a holiday :D
Why not buy a Mac Pro? You can use the configure option to get all the expensive options and pay £15701.89 ;)
Though I don't know how many fans you can add ............................
Let me be blunt, you are a ******g idiot for suggesting this idea, you obviously do not know much about computers, if this was any other forum your post would be considered trolling.
Have you gained a large sum of money or something?
a GTX80 is faster than a 5970
Should you go ahead with this build you will need a much bigger psu than 1000w more like 1.8kw or two 1000w which i think MM normally support.
You really should consider SSD's rather than the VelociRaptor or if you can stretch to it get both i think it would be really good for your current projects bit when editing vids etc
I cant resist any longer
