- 18 May 2010
Can I be your Brother from another Mother?
You would be lucky, but it is worth a shot. You can get a 9% discount from online brokers like Orange Wheels, but the lead times on Sciroccos are huge (3months+). I strongly recommend you get rear parking sensors - you might as well not have a rear window when it comes to visibility.VW will give me 7,5% off (I think I can get them to 10%) taking it down to 20k
If supplies continue to be this short and VW don't bring out a major revision to the Scirocco (which looks likely), probably more than this. Buzz from car journalists is that they expect the current Scirocco to be a future classic (although I think that is expecting a bit much).I think the car will be worth 12k in 3 years (if not more as used car prices are crazy here) so overall excluding running expenses it should not cost too much, but is 16k a crazy amount to pay for a fancy golf? I will finance some of it but not all.
True but being his first proper car its probably a better idea to stick with the 1.4. Also the 2.0 will be a lot harder to sell after as the world if full of people that only want a tiny engine or a Diesel![]()
Now the list price is 21 500 (pounds)
I'm old, so my opinion will have little sway wiv d yoof but I think the 5 door Golf GTi is where you should look. Fatastic all rounder and buy nearly new to get the right deal and all the spec. I am not a fan of the wide arse skee rock o, Golf is much more practical but then I am not trying to look cool or pull d birds in it.
I say go for it, as I'm biased and own a 2l tsi. Unless you need 5 doors I dont understand why anyone buys any of the faster golfs now the scirocco is available.
why does the most powerful 1.4 TSI have a supercharger and a turbo???
The supercharger improves power at low revs, turbo takes over at higher revs (~3.5k in the twin-charged TSi I believe). It's meant to improve driveability and smooth out the power band.
A turbo, I guess, gives better fuel economy.oh kk, so why not just fit a massive supercharger then which could cover all the revs??
You don't understand that some people don't like the look of the Scirocco?
Don't think that would work, its hard getting one FI device to cover the whole engine rev range, its either small and spools soon, or big and spools late.
Not great reliability so i have heard from many of my vw owning peers!
You get most of the good bits of the Mk6 interior in the 2010+ Scirocco (new climate control, steering wheel, cluster, media unit, gear sticks). The seats, door panels are unique to the Scirocco.Because the Scirocco looks gash and has aged terribly the couple of years we've known it, and with the golf you get mk6 interior.
