Spec Check
9 May 2010
Hertfordshire
Hi there,
This build will primarily be used for gaming, WoW, Cod MW2 etc. I don't do any video converting or anything but I obviously want a fairly punchy machine, loading programs quickly etc.
I chose the 5770 Vapor X as I read that they're very good cards, I also thought the 5850 might not be worth the £70 additional cost.
The case came standard with 4 fans hence why I chose it. I don't know about AMD Chips so thought to be safe I would get a CPU Cooler with a good reputation.
Any Critism would be appreciate :)
This is the updated Spec .. Any other recommendations?? Will the CPU Cooler and Motherboard be okay?
and why buy the expensive 5770
http://www.overclockers.co.uk/showproduct.php?prodid=GX-014-C3&groupid=701&catid=56&subcat=1515
they all perform the same, except for the 512mb version.
also as long as you know that that motherboard is pants at crossfire, it runs the second slot at a reduced speed, with the money saved from the cheaper cpu, this motherboard will do a proper 16/16 lane crossfire experience
http://www.overclockers.co.uk/showproduct.php?prodid=MB-251-GI&groupid=701&catid=5&subcat=1782
might be handy in the future? if you want a chaep graphics boost, just add a second card.
Ahh didn't know about the Crossfire, but that Isn't an Issue - Also with the 5770, I've actually found that card, but the Overclocked Version on a competitors site, just thought I'de add it to the list for reference though.
