Wait, what has a preference of OS have to do with someone's choice of MP3 player?
The way I see it is that yes the revenues of MS and Apple may be very close now but their products are very different.
Microsoft's is primarily a software company that makes a few pieces of hardware. Apple is primarily a hardware company that also sells an OS.
MS is dominant in the enterprise sector and that won't change anytime soon as it would be a logistical nightmare to transition thousands of users from one completely different OS to another. Also Windows based PCs are cheaper, the overwhelming majority of consumers shop on a limited budget and Apple computers usually don't fit into this budget.
Based on those things I'd say MS is in a safer and more stable market segment than Apple and would be a safer investment! Note that I didn't say better investment!
Actually, with the current raft of phones available, only a complete chutney ferret would buy an iPhone.
If you want a cheap, consumer smart phone for the masses then get an Android phone. If you want something a bit more special get an iPhone. That's the way I see it anyway![]()
Neither are a safe bet IMO. Now I am not saying that it's RIP Apple/MS but everything seems to be pointing to cloud computing and that is a game changer. If O/S's become less important then Microsoft loses it's grip on the market and there is no reason to buy expensive Apple hardware to run Apple software.
Surely the iphone is the more generic smart phone for the masses, and the android is better for the more technical user?
PC fanboy = person who refuses to accept that apple makes some decent products.Wait, what has a preference of OS have to do with someone's choice of MP3 player?
32gb iphone = free because I actually make use of my phone. Don't know why payg users buy fancy phones, if payg is financialy better for you then you clearly aren't going to make the use of a decent phone.And how much extra did you pay for that satnav ontop of your £400+ phone?
Iphone alternatives just don't have the massive stream of decent applications that make the iphone.Actually, with the current raft of phones available, only a complete chutney ferret would buy an iPhone.
Even though a cheaper android handset is more powerful ...
Both MS and Apple are software companies. There isn't even a hardware difference between a Mac and PC any more as both are built on a x86 platform. The only difference is the software that runs inside.
And how much extra did you pay for that satnav ontop of your £400+ phone?![]()
Only if you like a good tinker. Take a none Jailbroken iPhone and a non Rooted/Custom ROM Android and you will find Android can do more "Out the box"
The satnav that comes with the phone is actually a pretty decent app. Paid nothing for a famous satnav app after some software alterations.
