Is there any reason V-Power has gone up disproportionately to normal fuel? It's gone up 10p a litre since January, and has changed from ~4p higher than normal to ~7p higher than normal.
It's always been 7ppl more than regular unleaded?
But how would motorway services shaft us thenPrices should be the same across the country.
Still 120.9 for 99 ron at Tesco in York![]()
Whaa!? It's 2p more at my local Tesco...
I feel more torques y0 when i use vpower diesel. Not more performance per say, but the car seems more eager midrange wise.
What if we did a blind test where you didn't know whether V-power had been put in. Bet you couldn't tell a difference then.
The mind is wonderful at making us believe things are true and possible!
there were 2 shell garages near where i used to live, one always used to have Vpower at +4p and diesel 3p cheaper than the other garage, the other at +7p and diesel 3p more than the other. Bizarre
I'm actually putting in a full tank today - the cheapest super unleaded near me is Tesco for 125.9ppl
Should I definitely be using SU for a 2001 e46 330i bmw?
Not really. I doubt it's mapped for 97-99...
I use it religously in mine and can honestly not notice a single bit of difference. I use it because i had a load of sensors fail (read £800 bill) and MRC thought it could be because the map is for 98+ and i was using a mix of normal and super depending on if I could get it. Not turned back sicne and it's all running ok and has been for over a year now...
paid 117.9 at my local BP station the other day.
Oh well.
