Facebook isnt working for me either both on wifi or the vodafone data network. Mines a stock desire thats not rooted so probably a facebook issue.
Ahh thats good then
Now to work out why the market is playing silly buggers. Can someone try and download something and let me know if all is ok?
There is a new firmare update for the Desire.
1.19.161.5
For Vodafone users there is a thread on the forums here:
http://forum.vodafone.co.uk/topic/61520-htc-desire-firmware-update-available/
Just gone through the manual update procedure and it works fine.
Going through the issues I've had with the phone now and seeing what has been fixed.
Is this just for Vodafone then? I assume by manual update you mean telling the phone to look for updates instead of leaving it on Automatic.
If you mean downloading the zip and installing it from that thread, I wouldn't want to do that as its Vodafone (mine is stock HTC)![]()
Yeah ive always used @gmail too. but my defualt the phone logged me in as @googlemail.com
Not a big deal now tho all is sorted
I thought i messed something up by rooting
So what's different when rooted from say my handset that came out of the box unlocked and unbraded, well other than the Virgin Media logo when it boots?
Can anyone find me a genuine HTC Desire BLACK battery cover?
Even on their own website I only seem to be able to see silver and brown.![]()
This happened to me, i randomly decided to uninstall the market, i didn't think it would work!AGHRRR!!!
Market is still not playing ball!!! Decided to remove all the downloads that was not acctualy downloading anyway, turned off the phone, turned it back on and just tried to download something.
Still say "Starting to download......"
Realy realyyy don't want to have to restore after ive spent all morning setting everything up how i like it![]()
There are several advantages, that have been outlined quite a lot in this thread
In a nutshell, it means you can use various modifications on your phone, that will give you extra features (such as Apps2SD that you cant get until HTC port it over), performance boosts, remove rubbish put on by the networks, etc. Flashing Roms and so on.
