Just found some vids which appear to be using the new aptch somehow, shows the apache countermeasures in action, and another vid showing the more agile apache in action.:
Can't really say i notice much change in the agility of the Apache, seems to turn a bit quicker. He also has a blurb on how contermeasures work against tracers.
Apparently thats the new chat window at the top left, pressing the console key makes it larger according to the forum. Also infantry only mode is meant to be coming as well....which in most map swill probably make next to no difference since the vehicle count is anemic.
They DO NOT divert locked-on rockets.
They DO get rid of darts.
Flaring a dart after you were locked on WILL NOT save your ass unless you can lose their lock. The orange square will be gone.
In essence, I recommend you be fully aware of when you are darted. FLARE IMMEDIATELY! You will be able to flare again in about 10-15 seconds.
dont know what to do now
