I think its just so ATi owners can buy nvidia cards and boost their profits then they disable it again![]()
You not got the original cooler in a box in the loft somewhere?
While it was not intentional, due to the overwhelming positive response to the beta driver we have decided to leave the beta up with support enabled.
Therefore our WHQL certified drivers will continue to have this support disabled.
Wonder if theres any real substance to the veiled reference to beta drivers not having it disabled :S
For reference using the built in benchmark in batman AA I get 33/92/64 fps min/max/avg
That's 1920x1200, everything on max, physx on high and 4xAA forced in the ATI control panel (I couldnt guarantee the AA worked)
Edit:Just tried it again with AA off and I get 68 average so I guess it was on
Ok, just downloadin it from steam D:
I turned the option on in batman but it said "your hardware does not support Physx performance will be severly reduced" does that mean it's not working? D:
Didn't have the flags and the performance was awfull. Do I need to enable something in the nvidia control panel? I can't find anything about physx.
mm, ok. I got it to work buy plugging my second monitor into the nvidia card.
So it's working apart from not being able to get smart doctor to load. Doesn't seem to be anyway to get smart doctor to work with a nvidia card in
It all works fine but I can't find a way to make smart doctor work. Will probably have to take it out as I can't get much of an OC on my card without the voltage tweak.
God I hate smart doctor. I wish I had bought a reference card instead of this stupid direct cu one, would have been cheaper too.
AA doesn't seem to have a huge impact on the average framerate in Batman - just pulls down the max and minimum fps a bit but somehow the average is mostly unaffected.
Use MSI. I find Asus smartdoctor really buggy and can acheive a higher stable overclock using MSI.
Also if you set up your Nvidia on an extended desktop you don't need to plug anything into your card.
The average is worked out from the Min - Max.
