hey guys, not much of an update but id mention a couple of things anyway.
since im gonna need all the help with my brakes to stop from such a speed i stripped down both calipers and rebuilt them, was a bit of a nightmare
was dirt in the fluid that messed up 3 of the pistons.
Eventually got the piston out to find it had some scoring and a burr on it:
With similar scoring inside the caliper piston recess:
Was caused by pieces of grit in the system! This is despite there being dust seals and the main piston seal appearing to be in perfect condition!! Luckily the damage was not deep and came out very easily.
Rebuilt it with new pads and bled the brakes. This was the state of the fluid:
A bit skanky to say the least!
You can see its been a while since the pads have been changed!
the next update is that because of something happened today(which i will come onto later in the post) i decided to not go with my idea of having the intercooler in the engine bay.
I have decided to put it in the bumper area, now because of the large size of the cooler and the way the stock bumper wraps around the chassis area so tightly it meant that the bumper wouldnt have the physical density to contain the full cooler.
So i went on the hunt for another bumper, since it seems someone local has been using my front bumper to bounce there car off a few times a replacement was needed anyway.
Found this going cheap recently so picked it up including the lights that go in it.
Its a copy of a japanese bumper from FEED
As you can see it has much larger opening for air intakes, this will help to get more air travelling to the intercooler over a stock bumper aswell.
Suppose the final update was that today i got invited to santapod with redline magazine, was a lot of fun and interesting to see how the car did in its very basic setup(not much up on stock)
Arrive at pod at 10am, remove all the crap ive brought from home(food etc)
Have a wander around to see whats there and sign loads of paperwork to say im happy to die lol
Put the fuel back into my map to take it off economy mode, gotta love PIM voltage settings.
DRAG RACING
Leave it on stock boost for the moment, as im still on the basemap, thinking ill up the boost later on in the day when i get my 60fts perfect.
Since i didnt have a air compressor with me i just evened the tyre pressures out on the back to 20psi(since they are just old eagle f1s)and set the teins to soft.
So this is it, little bit nervous as not really sure what to expect and never launched a rwd car at pod before.
Drive around to the start line avoiding the water trap, move into position, rev up to about 5500rpm and go.
Pull of the line not to bad, once it hits 7krpm in 1st i get massive axle chatter and it shakes me stupid, change to second and pull to 7.5k, change to third, pull to about 7k and into fourth.........suddenly ive got no power, do the usual look in the mirror for white smoke(habit from owning a r5 turbo) look at the boost and ive got 0.01bar of pressure!!
Cross the line basically rolling
Feeling a bit disheartened thinking ok this sometimes happens to me but ill try again and hopefully the solenoids will be kind to me.
Pop into the timing booth to see what my 60ft was so i can see how much i need to improve(basically expecting a 14sec quarter and a 2.5 60ft)
Get given my slip to find ive done a
[email protected] pulling a 2.1667 which i thought was pretty decent since i had no power for some of the run.
Thinking if the boost holds together for the run im hoping for a 12.5 at 110mph+
Launch on the next run and get a 2.1445 60ft so a little better but since im still getting axle chatter i know my launches need more work.
Soon as i go into third gear again no boost, try in fourth and same again, nothing, cruise over the line at 17.0822@57mph lol
Shame really as i didnt even get to try a 1bar of boost
my first run only peaked at 0.69bar
SPRINTING
Feeling a bit miffed about not being able to see what potential my car has i decided to pop up to the handling circuit.
Here is a rough picture from what i remember, there might be a better pic when its in the magazine, you launch at the startline on the right and the timing stops when you come to a standstill at the end.
The picture doesnt really show how extreme the salom at the end was, much more tighter and the cones were closer together
Pull up the start, asking the guy where do you go, advises me to drive around it slowly to find where im going then come back around and go for it.
Before i had a go i asked what sort of time to be aiming for, few guys say people are averaging around 33seconds, anything less than that and your fast.
So first go and ive now discovered ive got no boost....at all, since ive now only got about 150bhp i just keep my foot in as long as possible.
dont get out of the second gear the whole way around and use my handbrake to slow the car down as the big corner tightens up, then basically understeer my way around the rest of the course(foot welded to the floor as havent got the power to get back up to speed again)
Nail the brakes very hard at the end to help pull some time back.
Guy gives me a time of 32.5secs
Feeling pretty happy with it as i basically messed up the entire lap and didnt really know where im going.
Ask what the fastest time of the day was and its fensport corolla running 600bhp on semi slicks with a time of 28.4seconds.
i then started to put some more runs in and clean my lap up
2nd run 31.7secs
3rd run 30.0 secs
4th run 29.7 secs
5th run 29.6 secs
6th run 29.1 secs
which im not 100% sure where that will leave me in the end but i was in 3rd position when i left them to it at 330pm
Not bad for a car with no power, rubbish tyres(still 20psi in the back) and havent touched the suspension.
Found compared to other people i wasnt braking at all in the corners when they were, im guessing this was pulling my time back over the big power evos/scoobs etc
So overall a few positives to take away from it and a lot of negatives.
POSITIVES
running 12s at pod in a stock twins rx7 is so easy its unreal, 10psi on a basemap with no boost in 4th, old eagle f1s, i easily broke into the 12s so that should be a good thing to everyone out there who fancies a go.
Also shows my car has decent potential when running correctly and on decent tyres
Also i didnt break anything, was little worried about the diff as i have no brace and that i might blow the engine but all was good!
NEGATIVES
to be honest its kind of my fault, i really shouldnt have asked to go with the car not being in great condition, really showed up when i needed it the most.
Im sure with boost, set of 888 tyres and decently set up suspension i would have won the sprint competition so need to address these issues
got some pics off my mates phone, god the quality is poo!!
few from sprinting
