No screen grab, but temps are currently 29-32C.
10 HDs
Server is idle.
Room temp 25C.
Here we go:
Cooled by a pair of 12cm fans.
P.S. Gotta love my WHS' idea of hard drive balancing!
Bloody hell that's a lot of drives. Do you buy them new or through the MM or similar?
Notice you've got a WD 'EARS' drive in there too. What method did you use to work around the sector size increase? I went for the jumper option in the end.
Theres an issue with EARS drives and WHS? Ive got one on my desk im currently filling with stuff to move to my WHS before it becomes part of the pool. whats the issue?
Well, pron does take up a lot of space....
The drives are either 'new' (2 of the 1TB were pulled from a WD NAS, but they've been replaced with the 2TB drives now) or from OcUK B-grade stock.
I didn't know about the 'EARS' problem. That would expalin the erratic performance I've been getting from my server, which I just thought was the data being balanced.
I've read most of that WGS thread and I'll have to take my server 'offline' for a while as I sort it out.![]()
You have enough space to remove the EARS... allign then re-add to the pool
Also whats the deal with the B grade drives?
