Hi guys, any of you local to Cambridge
yes
and equipped with some serious polishing kit?
no
I do all my polishing by hand. These guys will sort your car out though
Try Gliptone liquid leather, its very good and actually smells like leather.
[TW]Fox;16660125 said:As requested by Fett, who it seems went to special effort to bottle me up some polish before I bottled out of using polish, my quick story of DAS-6 woe.
Clayed the whole car, looking great, and decided to use my new polisher. Thought I'd be better be safe first and try some super resin polish on the boot lid.
Made a complete and utter hash of it. Couldnt stop the machine bouncing up and down on the paintwork. Scared myself to death, put it back in the box where it has unfortunately remained ever since, and I still have a sealed bottle of Menzerna on the side
What did I do wrong!
[TW]Fox;16660125 said:What did I do wrong!
You're not alone Fox. I found it a bit daunting at first. Not sure what the DAS-6 is like but my PC7424 took quite a bit of use before I got comfortable with what it was doing.
I made a complete hash of the first panel I polished (the bonnet) by applying far too much compound. I had it bouncing around a few times which was a bit alarming but applying a bit more downwards pressure and a steady hand helped keep it under control.
At low speed, it absolutely ruins your arm. The pain was quite unbearable at times meaning I had to keep stopping and starting. You do get used to it though so get stuck in and give it another go.
Once you've got the technique it's actually quite enjoyable. Time consuming, but enjoyable![]()
How loud are these dual actions? I need earplugs loud, or more bearable?
