simulatorman, ur saying that with the megahelm and noctua fan it will touch the first ram stick in the second slot ? cause i kind of ordered those and i cant reorder anything atm that will be sad to hear
ill have to figure it out some how.
anyways i do have a small question, if i do not plant to OC the cpu at all and keep the 980x at 3.33 ghz, can i get the ram to run at 2000 mhz ? or because i supply more voltage to the ram in turn i must boost the voltage of the cpu ?
ill have to figure it out some how.anyways i do have a small question, if i do not plant to OC the cpu at all and keep the 980x at 3.33 ghz, can i get the ram to run at 2000 mhz ? or because i supply more voltage to the ram in turn i must boost the voltage of the cpu ?
, i moved up to 7th in que
