I have an unbranded Desire (bought SIM Free), with no custom ROMs or rooting and the OTA update option has just popped up... should I do it?
I think it will work, seeing as it uses a custom kernel and someone posted about it being a kernel issue. From the sounds of things, the OTA acts like a patch as you obviously don't wipe during the process.
MCR is a great ROM but I have the £9. 99 p/a add free subscription for use of the kitchen. It will take a while on first boot so give it some time![]()
It changes your bootloader to 0.80 so you'll loe root as well and will have to re-root using the 0.80 files but I don't think anyone has tried this yet.
No confirmation on OTA changes either.
Quick question...
What charger(s) come with the desire as standard? I know that any micro-USB cable can be used to charge it, and I have several of these, but I'd like at least two mains-based chargers. Does the thing come with a mains charger?
Cheers Scottland, I think I'll do the same![]()
whats the phone like with standard android 2.1? all these 2.2 mods seem a bit of a pita by the discussions your all having.
Also is there a pc suite for it, like nokia suite, for texting from pc, file transfer etc etc etc.
The phone is absolutely fine on 2.1. Froyo (2.2) just makes huge advances forward for Android as an OS, so people obviously want it, it appears we will be waiting another week or two though before it starts to get stabilised.
It's fair to say the current Froyo version is an average bodge job, that said for the 2 days I had it running it seemed quite fine, so it's hopefully not going to be a nightmare to fix.
There is a PC Suite, but it doesn't do as much as Nokia's one. It's called HTC Sync.
Will be good to see how the real deal will be then.
Is there talk about the HTC Sync being improved? lack of text support would be annoying.
Also a couple of pages back there was mention of a phone very similar to the desire but had a keyboard, is there a name for it yet?
Don't forget it's Micro USB - not Mini USB like previous HTC's and other phones have been.![]()
I've gone to this ROM now:http://forum.xda-developers.com/showthread.php?t=674688&page=59
Much lighter on the battery, apps2sd working perectly (still have 138mb of phone space after installing a shed load of apps), did try the bravesoul rom but a2sd wouldn't work.
