Ok, I thought I would dedicate a thread to the new RC build im doing atm.
Its a Chris Foss WOT 4 MK2 Nitro RC plane.
So far I have the following
WOT4 MK2 Plane
Spektrum DX6i 6ch full range radio (tx)
Spektrum AR7000 7 Channel Reciever (rx)
5 x Hi-Tek Servos
4 x 300mm JR Servo Extension Leads
Align Glow Starter, rx li-po battery
imax B6 Balance charger
Sharp Craft Knife
Lead locks
Thin Cyano Glue
Rapid Setting Epoxy
Lead Locks
I still need to get a few more bits
SC46A-S AERO RC ABC ENGINE - 2 Stroke
Fuel Filters
Fuel Pump
Im sure I will think of more to add to the list
Anyway
Day 1 of the build
Thought I would start with something thats in the middle of the instruction book, purely as its probably the easiest thing to do, constructing the undercarrage section with the wheels and also the tail wheel. Done and done.
I had to pop down to the hobby shop to get the adhesives and some other bits, then I started on attaching the ailerons to the wing panels, uses thin hinges and cyano glue which will later be re-inforced by aileron control horns where the control cables will be fed to.
Next thing im going to do is im going to prepare the servos, getting the extension leads clipped on and the terminal connectors fastened with lead locks.
Keep your eyes peeled, I dont have a deadline for this so just peruse at your will
WOT4 MK2 Plane
5 x Hi-Tek Servos
Sharp Craft Knife
Lead locks
Thin Cyano Glue
Rapid Setting Epoxy
Lead Locks
Fuel Filters
Fuel Pump
Anyway
Day 1 of the build
