- 4 Aug 2008
- Manchester.
Mine was around 1200 at 19. Still 900 5 years later. (multiple incidents).
Because there much better than some generic fiesta/punto/corsa
In what aspect? Generally larger engine - Yes. Drives like a boat? Check!
Upsides and downsides.. nothing wrong with a fiesta/punto/corsa for a first car.
Just cause this is ocuk and youre not presenting an m3 to the board doesnt mean its a bad car - esp since its your first!
You really think a mondeo is in any shape or form fun to drive? Its a pure daily grind car.
Id say youd have more fun in something a bit lighter with better handling!
Toys is true - unless your budget is quite high
You want you first car to be a mondeo to last you many many years?
Source :Whatcar?it’s the way the Mondeo drives that sets it apart from rivals. It hides its size well through an almost perfect blend of supple, well-controlled ride and crisp handling, topped by great feel through the controls.
Without trying to patronise
Youre source is correct - welldone.
One problem but, see the word "rivals" ? That means its compared to a vectra etc! Hard contest..
I would say down a backroad that a fiesta would be more fun than a mondeo but having only been a passenger in both I guess the statement isnt 100% fair but it follows decent logic.
Also dont forget, more toys = more to go wrong. More to service and more to pay!
Ive given you my 2 cents as the saying goes - If youve convinced yourself on a mondeo then dont ask for advice since you clearly dont want to hear it![]()
I think a mondeo is the best out of the bunch.All im saying is youre writing off 3 of the most popular first cars on face value with no license and no legal driving experience on the road.
Good luck getting quotes in 3 years, atleast youll just be able to bump this thread when its finally time![]()
Using gocompare.com and that was the cheapest quote to pop up.
