Also if you wanted a little extra wire room you could flip the PSU round, so the wires are closer to the mobo.
I had the same problem with the CPU 8pin being too short in my K62 so I bought this (http://www.overclockers.co.uk/showproduct.php?prodid=CB-022-AK&groupid=701&catid=48&subcat=153) and it does the job great. It is very cheap too. Nice case though![]()
pretty easy. First get hold of some LEDs (i cant say where to get them from as i am not sure if the site counts as a competitor or not...).
for the case, it was a matter of removing the LEDs from the mounts, which are usually clip mounted (although the two on the front plate i found to be sellotaped in...). Then i peeled off the shrink wrap (wire cuters) around the legs, and snipped the wires just behind the LED (after taking note of the polarity). Strip the wires, trim the legs down on the replacement LEDs, solder them back onto the cables, and clip them in. I didnt put any shrink wrap back on because i dont have any, but i made sure the two legs were well apart so they wouldnt short.
for the fans, as above, except the one of the case fans, the LEDs were held in with a force fit. This required a considerable amount of pliering to get them out.
dont really know of any guides, but its pretty simple - remover old led, chop old led, solder on new led, refit led.
basically that lot, plus a (now white) led fan in the back (not shown), and power/hdd behind the front door
to do the whole case (10 or so LEDs) was about 20-25 mins
yeh ive got this case, and im gunna throw you a question, how the hell do you get your cables so tidy? mine are all over the place!!! the only thing i can think of is drilling some more holes but i want to avoid that!
Personally, I hate the side panel - looks stupid and over designed!
Too much mesh for my liking aswell
Overall though, your build looks good![]()
Nice clean build, shame about the case
Btw my old man has an original Antec 900, and to say they're dust magnets is an understatement.
XFX fan boy there is that an xfx mobo also ?
Nice
What sort of temps are you getting?
