Hows the battery life on this rom? WiFi Tethering work okay? (I need it for work )
I haven't flashed yet lol
When this has completed, your device should be at the 'recovery' screen. Select the 'wipe' option, then select the option to apply an update zip from sdcard, and select 'rootedupdate.zip'. This will take a little while, so go make a nice cup of tea. When the flash has finished, reboot, and you are DONE!
I haven't flashed yet lol![]()
I just flashed, but i didnt wipe.
Everything is as i left it, just a new rom
All works fine.![]()
Can you still tether with it do you know? Is it faster than the bulk standard rom?
The wifi tether turns on, my laptop picks it up and connects, but says no network access, not sure what i am doing wrong![]()
Can anyone tell me how to install this?
http://forum.xda-developers.com/showthread.php?t=694697&page=4
I don't want the baseball bat part though.
I guess you install it same way as you flash a rom?
Give it a go and see.
First you have to root your Desire, follow this guide Pauls r5 rooting guide
After you have root, get back into recovery like its described in the guide under "Entering recovery in future"
Download the new bootscreen and put it into root of C:\
Open CMD (Start->Run->CMD)
Type into the window the following commands
Code:adb shell mount /system adb push C:\bootanimation.zip /system/media/ adb reboot
FYI: ADB is the Android Debug Bridge, you can get more information here Dev Android
@potter1984 thanks for your work here![]()
Ive found a much easier way.
Download Root Explorer off the Market place (£1.90)
But you dowt have to go through the command prompts, just use root explorer, copy paste, reboot phone, job done
Just tried, works a treat.
So just move the apk file from /data/app to an app folder in the SD card?
Looked under Security and only see sim / storage & screen locksSettings > Security, if what you want can be done, it will be there.
