3TB hard drives by Seagate - end of 2010
  • Thread starter Thread starter ntg
  • Start date Start date
ntg
ntg
24 Nov 2008
Haven't seen this posted so I thought it might be of interest.
After a few weeks of rumours, Seagate’s senior product manager Barbara Craig has confirmed to Thinq that “we are announcing a 3TB drive later this year,” but the move to 3TB of storage space apparently involves a lot more work than simply upping the areal density.
The ancient foundations of the PC’s three-decade legacy has once again reared its DOS-era head, revealing that many of today’s PCs are simply incapable of coping with hard drives that have a larger capacity than 2.1TB.
The root of the problem is the original LBA (logical block addressing) standard, which can’t assign addresses to capacities in excess of 2.1TB. Originally set out by Microsoft and IBM as a part of the original DOS standard, the original LBA standard assigns an address to each 512-byte sector – the smallest physical block of data on a hard drive.
Unfortunately, though, the range of addresses is limited to capacities of 2.1TB. It’s a limit that until now has seemed so far off in the future that hardly anyone’s considered it a problem. “I think that’s what everyone thought,” says Craig. “Nobody expected back in 1980 when they set the standard that we’d ever address over 2.1TB.”
Craig explains that “we need to extend that to Long LBA addressing,” in order to get around this. Long LBA basically increases the number of bytes used to define an LBA address in the command descriptor block, but it also requires a supporting OS.
According to Seagate, this includes the 64-bit versions of Windows 7 and Vista, as well as modified versions of Linux, but it doesn’t include Windows XP. Not only that, but you may not even be able to see 2.1TB of a 3TB drive when using Windows XP.
Seagate says that its own tests have shown that as little as 990MB of a 3TB drive could be available to you when using XP.
“There’s also a GUID partition table (GPT) that needs to be implemented,” explains Craig, “for the master boot record.” Current master boot record partitions are limited to 2.1TB, so a new GPT partition table would also need to be used to see beyond this.
Of course, this is all fine if you’re using a 3TB drive as a secondary disk, but there are more problems to overcome if you want to use that 3TB drive to boot your OS. Unfortunately, the master boot record is a key part of the standard BIOS setup that motherboards have used for decades.
GPT was originally proposed as a part of Intel’s Extensible Firmware Interface [EFI]; a user-friendly setup system designed to replace the clunky ASCII-based BIOS. This specification is now looked after by the United EFI Forum (UEFI), and one of its many new features is a larger LBA addressing scheme, which would enable enough addresses to be handed out to drives with greater capacities than 2.1TB.
However, this presents a big problem, as many standard motherboards don’t feature a UEFI system. Some manufacturers, such as MSI, have introduced UEFI to a select few boards, but UEFI is still not the de facto standard. What’s more, any RAID drivers, if appropriate, will also need to support Long LBA if you want to put your 3TB drives in an array.
Basically, with the original LBA limit set at 2.1TB, it seemed pointless for anyone else to prepare for any capacity beyond this, so we now have a situation where many hard drive controllers, BIOSes, drivers and operating systems are all set with caps of 2.1TB, and this is going to take an industry-wide overhaul to overturn.
Although this involves a massive amount of work, Craig says that “many of the partners - you know the operating system, the BIOS, the RAID controllers - everyone has attacked it, and I think about 80 percent of the infrastructure’s ready to support it.”
“On the UEFI standard, we’re going to a Plugfest next month,” he continues, “to ensure that everybody is ready, and the IDEMA Group is also supporting them.” According to Craig, the preparation for the move to 3TB drives has also meant cooperation with other hard drive manufacturers.
Assuming that all the issues get ironed out, Seagate says that it’s planning to launch its first enterprise-level drives with more than 2.1GB of storage space at the end of this year.
Note: that 2.1GB at the end is obviously a typo.
So we will need UEFI, 64-bit OS and new partition table.
Your comments? I think it was about time that we start seeing higher capacities in hard drives. At the very least they will push the 2TB drive prices down. However it will require a bit of spending since only 64bit OSs will do the trick (well linux x64 is free but many users will fork out for Win7).
Good stuff, and hopefully others will start announcing similar capacities for competition to ensue.
only 64bit bioses with uefi can BOOT to a 3tb drive, which will no doubt be a 5400rpm drive with limited speed, 98% of people buying 3tb drives won't be buying them as boot/os drives but adding to capacity.
AFAIK once in windows it should see the drive fine and should be able to partition it with the new partition table without problem and use the full 3tb should be fine.
UEFI bios's have been talked about for like, 4-5 years and its made zero process so far.
2TB 5400rpm drives are constantly on deals at the moment from £85-100 in various brands, so its not going to push any drive prices down. The only ridiculously priced 2tb drives are Seagate enterprise oriented sata 3 7200rpm drives, assuming the 3tb drives are 5400rpm and aimed at storage and home users then its unlikely to change their enterprise/performance pricing, and theres no where for 2tb 5400rpm's to go in price.
Crazy dense platters. I feel sorry for the RAID controllers on desktop PC's having to drive these things.
