Macbook version question
  • Thread starter Thread starter ajf
  • Start date Start date
ajf
ajf
30 Oct 2006
Worcestershire, UK
I keep considering getting a Mac of some kind so I can learn about them.
I found an Apple reseller selling ex demo macbooks with the following spec:
2.26GHz Intel Core 2 Duo Processor
2GB of 1066MHz RAM, with support up to 4GB
250GB Serial ATA, 5400rpm Hard Drive & 8x Slot-Loading Superdrive
NVidia GeForce 9400M graphics processor with 256MB memory
Is this likely to be the current macbook or previous generation, and if so, does it make much difference?
Which version of OSX is likely to have?
They are £600 does this seem a fair price? Have about 6 mths warranty left.
Finally, I would want to connect to an external monitor, which is the 27" Hanns-G which is only HDMI - can you get a suitable cable for the macbook?
Thanks
Andrew
sounds good... is it an aluminium or a white one though? all of the aluminium ones are good, but the white ones break like crazy. Also, check that the disc drive works before you buy it - some of the early aluminium models had dodgy drive fittings.
To sum up, if it is aluminium, and the disc drive works, get it.
wilko49 - any link to the dodgy drives?
Saying the white ones break like crazy is a huge statement which isn't true.....
You will need an adaptor from Macbook -> DVI , and then a DVI -HDMI cable (or similar setup) but it should work fine.
Thanks for the replies. I did not realise the new Macbooks were also now aluminium, I thought it was just the Pros that were.
Not too worried as likely to be mainly used around house.
Unfortunately way past HE discount age..! Unless it includes OU courses?
Andrew
If it's like new then £600 is not a bad price. I wouldn't buy a plastic MacBook again but it's not like it will fall apart after 6 weeks.
I assume Macbooks take standard SATA 2.5" drives?
I have a Windows laptop with a new 320Gb Scorpio drive which I thought I could put in if I buy a Mac?
Also, any ideas if the 2Gb memory is normally 1 x 2Gb or 2x 1Gb?
Andrew
They aren't, only Pros are aluminium.
I think it's possible with OU, have a Google.
Yes standard drives but you might need a TORX bit to fit it.
It's usually 2x1GB.
Well, thank you for all the replies.
I have now purchased my first Mac, but not a Macbook....
Ended up going the whole way and came away with a shiny new 27" iMac :)
Think there is some learning to do but so far so good!
Nice one. Rolleyes because you tell him, wrongly, that the machine he was talking about doesn't exist. Way to turn it around.
An ex-demo macbook being sold now could easily be an aluminium non-pro macbook. We had one on demo til a couple of months ago. A reseller using them for training or whatever might be selling some now.
