My VID is 1.1625 currently at 3.6
That's the lowest VID i've seen so far. Lucky you.
4Ghz should be easy on that chip.Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
4Ghz should be easy on that chip.That's the lowest VID i've seen so far. Lucky you.4Ghz should be easy on that chip.
Comparing to above scrennie, Stock, 3.2 OC, 3.5 OC and this last one, 3.6 OC, the VID stays the same in Core Temp.
my q6600 with 1.2250 vid is overclocked @3.6 with 1.4v in bios but everest shows 1.31v idle & 1.28v while playing games.
I have been running my spare Q6600 @ 4GHz using a H50 @ 1.375 volts on a P5q Pro![]()
it is 1.225![]()
I may well go for 4ghz currently using 1.425 volts for 3.6ghz temps in the high 50's running prime95 for a few hours. Using a H50 cooler which for me has been the best cooler I've ever used.
