Clutch would have to be totally fubar to slip while cruising along at 70 surely..
Have you tried going faster? Try 140 or so and see what the RPM is.The car supposedly has a 145mph top speed but doing over a ton brings it into the redline.
Why not? He's happily done 100, so a bit more isn't going to harm. It could all be over and done with, from 70, in less than 60 seconds and a mostly empty road.Not really the easiest way to test is it?
I've driven at 140 in Wales before, in the Bangor area (I have a good friend who is going through her PhD there).Not sure where you live but try finding an empty road long enough to do 140mph on in Wales safely.
If he doesn't drive at 140, try 120. The point of the exercise is to verify whether it can drive "through" the limiter. If it can, it's just the rev counter being weird.
If it's slipping it won't get to 140. If it isn't slipping then 140 will be fine.Telling someone to drive at 140MPH to see if they're clutch is slipping is amongst the worst advice I've seen here.
Wouldn't be anywhere near as much fun!If it's idling at 1200rpm and sitting at 4500rpm at 70 then surely it's easier to just nail it in a lower gear first and see what happens?![]()
Hi. Doing 70 mph in 6th brings up 4500 rpm on the A55. Its usually around 3000. Does anyone know what could be causing it to go that high? I know the gearbox is quite short ratioed but it isn't that short.
Does anyone know what could be causing this?
