After reading all the guys on detailingworld raving about claying your car, I decided to give it a go with the meguiars quick clay starter kit. After (every) half a panel it looked like this :
http://public.blu.livefilestore.com...uTZiy5tItvdv-EUDX1ucsQ/20062010254.jpg?psid=1
However, I failed to notice any visual change... I've done about half the car, and deliberately only did half the bonnet, but I fail to see a difference between the bit I did and I didn't do, sure the clayed bit feels smoother and is slipper, but looks wise
Are you supposed to see a difference and if so, could I have done something wrong? I have kept it wet enough...
