Lo peeps, needing some case-techie's to advise on the best case I can get for about £100
Looking to invest in a 5*** series card at some point, possibly xfiring at a later date so need something that has space. Not knowing a huge deal about cases I've had a thread before but have decided against the recommended CM690.
Any suggestions? Or should I be asking other questions? Id need a case that has dust filters (even to buy as an extra)
BTW what's the best way to cool a case with fans? Does a front intake with exhausting out the back and top, sufficient? My case will be sitting close to the floor - up on a small block of wood to get it off the floor but not by much. In terms of dimensions I'm leaving it to you guys to advise.
I'd like something not too over stated as I'm 34 and don't give a **** about showing off to mates so something classic would be ideal/.
Cheers
Cheers
 if it's going to be in the new living room she wants it plain....i.e. black. Now I'm not overly concerned about a HUGE case but I@d like one that's big enough and fairly plain to look at...or clean cut lines
