Every woman complains and nags about this. GHDs.
I haven't heard one complain about this? there are cheaper alternatives but girls know that GHDs are the best so it's usually best not to skimp in this department
Because they work, I use GHD's and I've used cheaper brands and they don't do as good a job.
). I dropped them on a carpeted floor and they snapped. That exact day, I was in Birthdays buying cards, picked up a cheap pair(can't remember the price but CHEAP) and subsequently used them for years without fault. And this is someone who spends on average £40 for a hair cut.
GHD's are the best. Toni and Guy do some good ones as well for about £50~ if the GHD's are too expensive.
I hate the way everyone claims GHDs are the best. No, they aren't. There are far cheaper alternatives which look and do exactly the same job.
Do girls even bother about GHDs anymore? Probably not, yet everyone on here seems to think they do.
Yes and like Apple, they are over hyped and generally on par with the markets cheaper alternatives. It doesn't take a load of research either.
I'm just saying to the men out there: Not all girls follow the crowd and demand a set of overpriced GHDs.
I've been getting my hair straightened with GHDs at T&Gs for the past 4 years and still maintain the exact same results with the cheaper variety. As does my GF and a lot of girls I know.
Spot the lack of a woman . . . .![]()
*Walks away*
How long is your hair? Massive difference is straightening short hair and long hair effort and time wise.
I have done research and brought a pair Babliss 230 which were supposed to be amazing, same with Kodo's and T3's. Always went back to the GHD's as they done my hair much quicker, didn't snag any bits, unit stays cooler in my hand, less effort to clamp shut (makes a difference if you are spending 5-10 minutes using them).
