I think from looking around you will be looking at a minimum of 1200w on the psu to run a pair of 480s with overclocking, another chap on here with 2 470's was pulling 1kw at full load
Its not worth spending £1000 ~ on two Fermi cards when you could have a 5970 for £500 ~. Plus the new ATI cards will be with us shortly.
I swear to god Jigger your maths is utter rubbish, since when does 2 x £380 = £1000
How shortly are the new ATi cards coming, I didn't think they were out until Autumn at the earliest?
LOL you mean £390. Never seen them and they must be the 7 best priced GTX480'S IN THE WORLD. But they are still over priced.
Thewill pass...
Your going to be close on the limit looking at your system.
List your full specs inc fans sound card and so on.
wow... Acoridng to the above graph thing my setupi pulls 450w on GPU's.... and i wipe the flore with all 480GTX setups and some tri 480GTX setups :O
I don't play 3Dmark. But seeing as you asked:
Yea, probably a few k lower than heavily OC'd TF setups, but then again when has Vantage reflected realworld performance? I was just pointing out that your claims as to what your setup could do in comparison to 480 SLI setups was a bit disingenuous.
So you play crysis benchmark then lol. There was a review that showed nvidia being much weaker in game with there average fps when comparing to there benchamark results. That 1 review basically showed that benchmarks mean little when actually using fraps to play through the game as the gtx480/470 were not nearly as strong when comparing there fraps results in game compared with there high benchmarks results.
Because the vram is not doubled in SLI. A GTX295 only has 896mb of effective memory.
