Braking: How many fingers?
28 Feb 2006
No longer riding an Italian
Started with four, but moved to two after a couple of months, since then I’ve stayed with two, even fitted pazzo shorties on the R1; although I find I use three to four fingers fro the clutch still :D
I don’t use the front brake when riding much, it’s only when I’ve misread the road and need to shed more speed than expected, but that’s not to say I don’t know how to use them – I always practice heavy braking, never know when you’ll need it!
18 Oct 2002
Coventry
Depends on the bike, my VFR800 i can use 2 on the fronts since changing to ebc pads and it stops amazing well. On some of our old bikes such as the BSA Roundtank it has two rear brakes and i have been known to use my feet to slow down at times. . .
4 Feb 2004
Fife, Scotland
2 here, always. Been doing it that way for years. Engine braking on the Mille is pretty good though. :p
Rear brake, like all RSV's between 1999 and 2003 is however, awful, if it even works.
31 Oct 2004
Harrogate, North Yorks
Mine got to the point where it wouldn't even hold me still on a hill any more at one point! :eek: . New fluid and pads has made it much better but I bet it won't last too long!
1 Aug 2006
I went for ride down the coast last night and took note :D 2 fingers for brake and 3 for clutch middle finger on the clutch for pulling power and the other two for slight pressure and comfort.
14 Mar 2005
I always user 4 fingers on both road and track. I've never had trouble with needing more on the bar and 4 allows me to gauge the brake pressure best. Plenty of stop if I need it! :D
I've tried 2 finger braking and it worked fine but I've simply gotten so used to using 4 fingers that it feels "off" to do anything else.
6 Mar 2010
I only use three because i cant reach it with my forth! Should probably adjust it but it doesnt really make a difference. I try not to brake just accelerate! ;)
