I'm going to Bluewater at 7:30am tomorrow got 2 reserved![]()
If you've reserved, is there any need to go in early still?
Well, it doesn't seem too promising to be honest.
The Antenna issue here (as someone posted above) is equally concerning.
In short, it seems that actually picking your phone up reduces signal quality quite a lot.
I'm still surprised Apple could have let this slip? Will be interesting to see further developments.
It has also been noted that AT&T in america have rubbish coverage, reviews have mentioned that the phone suffered from less dropped calls as opposed to the 3GS...
I also think my desire signal reception is bad...Also, equally worrying, if you actually pick the phone up and hold it, the signal quality rapidly depletes as it hinders the antenna. (Link and video)D
Wonder if the Bumper will remove the resistance caused by touching the antenna? Though my assumption would be 'grounding' yourself with it would make it actually a better antenna...Well, it doesn't seem too promising to be honest.
Anyone who may of had previous launch experience with the Manchester Arndale Apple store may be able to answer this..
But how long would you expect the queues to be at 8am tomorrow morning for that specific Apple store? Very generic and likely tiring question, but i'm just wondering how early i should get there..
So can I "restore" a 3G backup straight onto my iPhone 4?
Just made my desire signal reception drop from 3 bars to 1 bar by picking it up and holding it/moving it around![]()
Think i will give up my iPhone 4 pre order to wait until these issues are sorted out.
My friend in the USA doesn't have this problemBit hard to sort out the Antena issue really
ps3ud0![]()
Nooooooooooooo!!!!!!!Good question... if the backup was made from an iOS 4 install, absolutely. If it was made from 3.x.x, maybe not. It's the software that's the deciding factor, not the hardware.
