- 11 Dec 2005
- Cheshire
Kryton Extreme Intel Xeon X5650 2.66GHz EVGA SR-2 Overclocked Bundle @ £2,999.99 inc VAT
Designed by experts the "Kryton Extreme Intel Xeon Overclocked Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. Our Kryton Extreme Intel Xeon SR-2 Overclocked Bundle is a special bundle which we hand overclock to the highest stable speed we can achieve this can range from 4.00GHz to 4.20GHz and beyond.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz + overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 12GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- Dual Intel Xeon processors delivers 12 core/24 threads of processing power
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
- 4 Way SLI Support
Bundle Specification
- CPU: x2 Intel Xeon X5650 2.66GHz @ 4.00GHz +
- Motherboard: EVGA Classified SR-2 DDR3 Dual Socket Motherboard
- RAM: Corsair Dominator GT (6x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel
- Cooler: x2 Prolimatech Megahalems Performance CPU Cooler with 2000RPM Sharkoon Silent Eagle 120mm Fan
- Artic Cooling MX-3 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Warning
This motherboard is very large and only fits into very few Tower cases. Please ensure your case has the correct internal dimensions to house this motherboard bundle.
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £2,999.99 inc VAT.
ORDER NOW
- 4 Way SLI Support
Service Package
Warning
ORDER NOW
