BSOD!! :(
13 Feb 2009
London
Hi,
I keep getting freezes then restarts.
Says,
Problem signature:
Problem Event Name BlueScreen
OS Version 6.1.7600.2.0.0.256.48
Locale ID:1033
Running Win7 64bit
Never had this before, so all new to me.
Any idea what's wrong ?
Cheers.
It could be a number of things, but an underpowered PSU gave me similar problems.
This is the PSU i have.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-CS&groupid=701&catid=123&subcat=1084
My system
i7 920 @4.2 temps 100%load temps are 77 74 75 75
5970 @850 1200 (never had problems with it clocked)
Ram. Patriot Viper 6GB
Need more blue screen info tbh, copy everything in.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA80097FF070
BCP2: FFFFF8800480667C
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\062710-21730-01.dmp
C:\Users\Marks\AppData\Local\Temp\WER-34928-0.sysdata.xml
Cheers.
I'd try everything at stock, this heat might be to blame I guess.
EDIT: or just lower your CPU a bit first, to say 4GHz, I doubt you will notice the difference, unless you are a benchmark freak LOL
Only seems to crash when i clock my card. don't get it, was ok before, volts are fine and temps.. hmmmm odd. running everything on a Asus P6T Deluxe OC Palm Edition.
Any idea ?
P.s/ sometimes it's fine after good time playing. but then bang gives me issues :(
Cheers.
The bugcheck code points to the graphics device driver which means the problem probably lies with the driver or the card itself. If it only crashes when you clock the card then there is your answer. Perhaps try a different driver.
I have tried 10.4 5 and 6.
Still samething :( can't really RMA it. as it only seems to happen just on a little bit of clocking :( is it normal for the gpu 1 to go up2 100% usage now and then on idle ?
I was getting something similar 2 days ago, cleaned out the heatsink on my GPU, cleaned and applied fresh arctic silver to it and it's been fine since. Worth checking with the weather being so hot recently.
Backup all your computer files. This means you need to save important documents like essays, data sheets, presentations, programs, etc. You can easily store it to a flash drive or on a floppy disc.
Search for the operating disc that came with the computer. If you have lost it, you can always purchase a new one for your operating system. Remember, in order to repair Windows blue screen of death error, this disc is needed otherwise it just won't work.
Now put your disc into the computer and restart your system. It will prompt you to press a key in order to boot from the CD. It may not show up though if your computer isn't set for booting from the CD, so you need go into the computer Bio to change the settings.
Now you will see the win xp blue screen error again with words appearing at the bottom of the screen.
Press continue and hit F8 once you see the agreement document come up.
To fix blue screen of death, pay attention to this detail for the next page. You will see a Repair, Delete Partition and Quit options. Push R for repair. If you cannot find this option, it should say Partition which is a part of the computer memory. Fixing blue screen of death was easy, eh?
