- 5 Aug 2006
- Derbyshire
I thought that the 150 had a different turbo, injectors, clutch and the intercooler is front-mounted not side mounted. I have no proof and cannot say for sure though.
Why do peolpe just post 185 then LOL? Put some substance with it! Im asking for opinions and help as im new to the TDI!
Anyway i have 0 idea if its true, i just went by the reviews of the remap on this site...
5th one up from bottom..
http://celtictuning.co.uk/vw.aspx
A mate recomended them, id be happy with any improvment not that i dont like it as it is but more is always better, long as it dont trash other parts as you guys mentioned.
I went into exact reasons for thinking it's a bad idea![]()
Yea you did further down the posts.. Apologies Knee jerk reaction!
I have called up the Celtic place and they confirm its 100% within the egine saftey paramaters..
Is it still a bad idea??
If 130bhp isnt enough for you, then just buy a more powerful one in the first place..surely?
I know you've already bought it, but should you not have bought something that suits in the first place?
It is enough and i didnt even think about a remap untill sombody mentioned it, apparently the MPG will increase also.
The spirit of these forums is buying somthing of a lesser spec and running it at a higher spec (OC) which is fairly simmilar to what the remap is doing i guess.
Not really, the 2.5 V6 TDI is worthless, the 1.9TDI is better.
Edit: Also I think 150bhp model was remapped by VW to 180bhp(?) in the golf anniversary edition of the diesel gti.
[TW]Fox;16864865 said:There was no 130bhp pre PD engine, the biggest was an astonishing 110bhp.
Nope, this was the 1.8T 150 which was 180bhp in Anniversary form.
