X10 Root update.
New step 4
http://forum.xda-developers.com/showpost.php?p=6993912&postcount=815
Update v3 - remove old step4 folder
Changelog
does not remove Mediascape (solves headphone problem)
patches corected su
patches superuser
changes device name to x10i
changes firmware version to R2BA020
adds mms
adds facebook
adds backup
adds ADW Launcher as default
added full apn list (no more manualy config APN)
added clasic Music player
added arabic font
added hebrew font
moved all cleanup to Step5 - now you have an full rooted rom
adds missing file for step 1 (copy it into step1 folder)
updates step4 (clean root) (copy it into step1 folder)
adds step5 junk cleanup (replace existing folder with new one)
adds step6 rom customisation !! default rom is black
RECOMANDED UPDATE PROCEDURE
step 1 (no need for factory reset)
step 2
step 3
step 4 - You have an fixed root with complete Stuff inside
step 5 - remove useless apps
step 6 - customize ui as you like (happy play / can be dona as many times as you wish / this is independent)
"andy" Can you test please and let me know the baseband number.
