- 23 Nov 2009
- North Leicestershire
If you want speed and silence you should consider a non reference HD5870 such as the ASUS Matrix, Asus V2 or the Sapphire VapourX.
Even though you have the money for a GTX480 the premium isn't worth it IMO for an additional 8% performance plus you have to bear with the noisy Delta fan. Non reference GTX480 cards cost a bomb and make the HD5970 look like good value for money.
I would try and avoid multiple video card setups if you have the cash for a single fast card. SLI/Crossfire setups are always reliant on driver releases for support and performance fixes. Nvidia is slow at getting out drivers but they do work and AMD gives monthly driver updates but can be hit and miss in terms of reliability.
some good points ocuk don't sell the matrix yet do they?
