WD Scorpio Black 320gb - Considering Purchase
22 Dec 2009
Upper Skurt
Hi,
I am thinking about replacing the hard drive in a laptop with a Western Digital Scorpio Black 320gb drive with 16mb cache and 7200rpm.
Would anyone using this specific drive in a laptop please be able to give me some feedback about system performance, noise, vibration etc?
Rgds
Binty
These are very quiet drives and very fast also. One thing you might need to check if you have an older Laptop is whether you need a BIOS update to support the drive as is the case with some older Laptops. They are great drives however.
Phil,
Thx for the feedback.
I think I should be OK as my laptop is running the latest BIOS which supports AHCI and the current HDD is SATA. I notice you mentioned that the drive is quiet, however, what about vibration?
Rgds
Binty
I am having second thoughts on the purchase of the WD Scorpio Black 320gb but only due to considering the WD Scorpio Blue 500gb drive.
The reason for my indecision is that I read somewhere that due to the aereal density and number of platters in the Scorpio Blue 500gb drive it performs just as well as the Scorpio Black 320gb drive.
I think that the Scorpio Blue has the 500gb over 2 platters whereas the Scorpio Black has the 320gb over 3 platters and even though the spin speeds are fster for the Scorpio Black then aerial density is more eficient in the 500gb Scorpio Blue.
Can anyone please confirm if the above is correct?
Rgds
Binty
A 500GB (or 640GB) disk will have slightly better transfer rates but it will be slower in real world use. Like I said if you want the best of both the 7K500, only quicker drive is the Seagate XT with the SSD bit.
