Hi Folks, I'm sure there are loads of similar threads, but I'm in a tight spot and need some help. My computer has totally died and I suspect Mobo/CPU as PSU is still powering Case Fans and GFX fan, but MoBo powered fans do not start and I get no beeps, post, etc and it makes no difference if i remove my GFx card. Rather than start trying to replace one or the other I 'm just going to get a new CPU/MoBo as a minimum and rebuild from there.
Having looked about I am totally confused with the latest Intel/AMD offerings, as my knowledge is rather out of date (I caught the early Core 2 Duo wave).
My Old System
E6600 C2Duo
P965 Gigabyte DS4 board
4x1Gb DDR2 533 ram (old & slow)
G8800 GTS 512
Intel 160gb SSD
OCZ MODXSTREAM PRO 500W SILENT S
plus HDD, DVD, DVD-RW.
20" 1680*1050 Monitor.
Whilst it wasn't up to date it was pretty good, and have no trouble playing 2009 games.
Needs
I game mostly, at 1680*1050, don't do very much movie editting or ripping, some photo editting, plus the usual surfing & office.
I don't want to step backwards from where I am and want to maintain 4gb RAM.
Budget
I don't really have a budget, becasue I don't understand what I am buying. I want something better than my Core 2 Duo. I guess I have between £200-£400 to spend, as that seems about right for a mid range system.
That said, if £20-£50 gets me a much better component I'm happy to stretch myself.
I wasn't planning on replacing my 8800 GTS (yet) and ideally I'd keep my 500W PSU as it is only a 8 months old. If I could get much better perfromance than my 8800 GTS for a modest outlay I'd be interested, but I'm not sure I can.
If I can keep my RAM, great, but I don't know how much I am limiting myself by doing so.
Questions / Comments
I don't see much difference between an i7 920 and a i5 750, but equally don't undertand the other 2 core i5s.
The AMD line up is very confusing, although I have been recomended a X4 955, as a good alternative to a i5.
I take on board what other threads have been saying about the intel sockets going out of date next year, but I am not likely to update my processor until both that and my Mobo are obsolete.
I can't afford to wait as I have no home PC at the moment.
Any recommendations, help, advice and combinations would be great.
Many Thanks,
Davey G
My Old System
E6600 C2Duo
G8800 GTS 512
Intel 160gb SSD
Needs
Budget
Many Thanks,
Davey G
It's at the top end of your budget of but the 5770 is a great card, still you don't _need_ to upgrade that atm if you don't want to.
