- 27 Jan 2003
- Chesterfield, UK
Currently running a V2000 with PA120.3, D5, Apogee on 775. I used the Masterkleer tubing with 1/2" barbs. Can't remember the size but it slipped over the barbs and with a hairdryer it shrank over and produced a water tight fit. I prefered this over jubilee kits and never had a problem. Obvioulsy things have moved on so I'm looking for some advise on my I7 setup.
I'm planning to buy a 980x or one of the new 970. Graphics I'm running a 5870. It needs to be totally silent but have the flexibility for some heavy tweaking/benching when needed.
My new build is based on the 800D and I have just bought
XSPC RX360
EK250RES2 Multioption V2
3X 120mm AKASA AK-FN059 HDB Viper Fan
For the pump I'm looking to use my existing D5 with a EK-D5 X-TOP?
For graphics I'm looking at the EK FC5870 5870 CF, Acetal, Full Cover Block?
For CPU the Apogee XT?
I'm also thinking of the Aquaero 4.00 "Powerbooster"? to regulate the fans and possibly the D5 but I'm not sure there's going to be enough watts spare with only 45 watts on tap.
I'm unsure about what connectors to go for and tubing. I like the bitspower stuff. I would like to be able to easily remove and add things. Also unsure about filling. The res might be a pain, fill port at the top of the case?
Any advice would be greatly appreciated.
XSPC RX360
