Water Cooling Advice - Super Quiet Temp Controlled
I thought you might prefer the look of the kryos, really is a fantastic looking block, the supreme hf full nickel is also a nice block but if you prefer a simpler look.
Performance of the two blocks is virtualy identical so as already said, go for the block you like the look of most.
My HF is the black acetal version of that. The universal version comes with two different top brackets, the one in the picture above and another bigger one with lot's of holes. I can see Intels i3/i5 replacement using the same spacing for the mounts as it's only a pin less than the current 1156. i7's replacement though may be bigger as it's 2011 (i could be wrong) pins. EK did bring out brackets for the original supreme for the i5/i7 sockets so they would more than likley do the same for any new sockets.
Well worth going for EK just for that. Cheers.
If I go supreme thats the block I'm going for. Will look nice in the case.
was talking about the silver one which was reviewed, others will probably perform worse than the HF
Taken from skinnee labs
"The silver versions of the XT have a .925 silver top and base"
The reviewed version clearly has a copper base so the silver version will be even better.
there's not much difference between copper and silver in terms of heat conductivity - less than 10% difference - more like 5% iirc. If money's no object and 100 quid for a degree or two if that might make sense I guess...
I wasn't suggesting to get the silver version in the first place, hw91 mistook the reviewed version for the silver one.
Gone for the following, Wife liked the Nickel :eek:
EK-Supreme HF Full Nickel Universal and EK-FC5870 - Acetal & Nickel Full Cover.
Tubing I have gone black XSPC 1/2" with Chrome compression fittings. Should look nice.
Will post some picks once I have it all installed.
Cheers for the input :)
When your Supreme HF arrives if the second bracket is'nt visible check under the foam at the bottom of the box. That's where mine was. Don't know why they did'nt put it in the fittings tray at the top but there you go.
