- 25 Oct 2004
No the ST clutch was rock solid. Simple test on the ST to see if the clutch was slipping was to put it into 6th @ 30mph and floor it.
If the rpm increased rapidly and speed didnt then the clutch is knackered, if you accelerate then its good. It was also relatively low mileage so was unlikely to be knackered at 38k miles, the BMW on the otherhand is at 117k.
Even then its not really a measure of a clutches wear, a colleague of mine drives an Astra with 268k on the clock, still original engine and clutch!.
