- 17 Jun 2009
- Swansea
As the title says, i'm going to put AVG on a note book. Will it slow it down or is there another AV i can use?
If you have Win 7, you can also try Microsoft Security Essentials.
Don't need W7 for MSE, XP and Vista are fine with it too.
AVG free is good enough for laptops.
I use it with both mine, and my desktop too.
Interesting. Thought that was a Win7 exclusive,
AVG free is not good enough for anything these days........................
is this just your personal opinion or do you have something more substantial.
As according to the listings, it seems good enough overall.
http://www.av-comparatives.org/images/stories/test/ondret/avc_report26.pdf
), and I much prefer it to the others. It's pretty light on resources and I've never really had an issue with it. I might try NOD32 when my license runs out though..Opinion based on experience and numerous tests, if things have changed in it's favour recently then great but it wasn't doing at all well previously.
I have used AVG free for a few years now, and its always done very well in test.
I can't think of a period of time that it has dropped the ball, or at leats had serious issues that would cause it not be used.
If you are not sure yourself, TBH you maybe should not discount something so flippantly.
Not saying it is the best out there, but its definitely one of the better AV products, and probably the best FREE one, from numerous tests I have read.
From your comments, it would appear to be very poor, to the point of been dangerous to use.
Ninja edits i see![]()
