Update from quidco rep:
" If you buy a £15 smart phone tariff- the checkout will split it as £10 and £5 add-on but this will not affect cashback. I hope this answers your query. "
I ordered this tariff, however my cashback has started being tracked this morning as "expected £25 cashback".
What gives?
Everyone's has tracked at £25, it should be uplifted to the correct amount in time.
Just ordered this... I'm on O2 already so do I really have to cancel my current deal and get a PAC code etc? Or will they just transfer it straight across onto the new SIM?
basically there the same tariff.
just the iphone tariff has visual voicemail included which only the iphone has.
you will require an iphone for the tariff to work though, as it will only work over activation on itunes.
