- 18 May 2010
- London
If you want to upgrade your 5850, then probably your cheapest/best option is to just buy another 5850.
I don't agree with this.
A 5870, 5970, and GTX480 are all a BIG upgrade from a 5850. A GTX470 is an upgrade for DX11 performance and features, but a lateral move in general.
You certainly go against the grain with your opinions.
ATi makes two cards and NVIDIA makes one card that are very significant upgrades over a 5850 and "worth buying".
Out of that list, only a 5970 would be. A 5850 is only a few FPS less than a 5870 and less so clock for clock.
Sorry, you're wrong.
Blah Blah Blah
I could go on, but it's pretty obvious that from a performance standpoint the 480 and 5870 are an upgrade over a 5850.
Soooo the only game you would notice any difference is Metro... WOW!!!
There is no possible way to justify upgrading from a 5850 to a 5870. The bench marks you've shown do little to convince.
You say you care about giving good advice.... but you're not.
The 480 would be an upgrade (again, this is game dependant) but still not by enough. And if you were to OC the 5850 it would become a marginal at best unless Physx and CUDA are important to you.
I think that doing nothing and keeping your current card is always the question you should ask yourself before you buy a new one. Especially when you already have a high spec CURRENT gen card!
Joker.
Joker.
