but he could atleast choose one that uses 100% cpu usage.
on the first pass i get 60% cpu usage at best , on the second pass 80-97%
x264 is obviously going to favor less cores if they are faster cores wheres handbrake which he originaly wanted to compare can max out 6 cores easily
heres stock 1055t results
handbrake can use multiple cores properly , this can not results are not a good comparision because anyone with a 6 core cpu wouldnt be using an encoder that cant use the cores.
[edit] still faster than the stock 920 someone linked on the benchmark image up above though, this is why i always say reviews are pointless without cpu graphs these days because the results dont display whats really going on
but look at my cpu usage graph...encoded 1442 frames, 64.59 fps, 3898.70 kb/s
encoded 1442 frames, 64.84 fps, 3898.70 kb/s
encoded 1442 frames, 64.02 fps, 3898.70 kb/s
encoded 1442 frames, 64.62 fps, 3898.70 kb/s
encoded 1442 frames, 25.62 fps, 3971.34 kb/s
encoded 1442 frames, 25.56 fps, 3946.44 kb/s
encoded 1442 frames, 26.47 fps, 3968.49 kb/s
encoded 1442 frames, 26.04 fps, 3953.60 kb/s
System Details
Name AMD K10
Codename
Specification AMD Phenom(tm) II X6 1055T Processor
Core Stepping
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Stock frequency 3300 MHz
Core Speed 2812.5 MHz
FID range 5.0x - 16.5x
