2007 Bentley Arnage Condansation problem
it's doing it because it's not sealed (as you know). Slip some sillica gel packets into the headlight until the condensation is gone. Seal it up properly, done. I still wouldn't be happy applying that fix on a Bentley though.
This really doesnt sound like the advice of a Bentley authorised dealer to me.
I would have thought that rather than trying anything himself, he will have this resolved by contacting Bentley. They will likely take it fairly seriously that he has been fobbed off like this.
They probably will actually, they are very good when it comes to no compromises customer service. However, if you don't have a warranty or credit card to wave at them ...I'm not so sure.
Worst "my dad's got a Bentley Arnage with condensation in the headlight" thread ever. :o
How about using silica gel packets behind the visible housing?
Didn't we already have a thread on headlight condensation in a focus was it?
I believe they left it with either the bulb removed (in it's bracket etc so just pulled out the back) for a day and it pretty much sorted it by the end of said day?
Memory isn't my strongest point but I'm sure (as always) someone else, with more of a need to help than I, will confirm/correct/deny and maybe even link to the relevant thread.
Hi
My dad has a 2007 Bentley Arnage.
For the last year there has been condansation in the headlight, it has been back to Bentley and they say its a common problem and they all suffer from it.
Is there any way this could be cured? Or any advice on how it starts...
Thanks
I had condensation in one of the headlights on my Honda Accord after the garage changed a bulb on the MOT and left the plastic sealing cap off it.
I waited till a hot day, then removed the cap again and went on a long trip, driving for 2hrs each way with the cap off and the headlights on (lots of airflow, warm dry air outside, headlight heating the inside). So by the end, the inside of the light cluster was warm and dry. Then at the end of the trip I put the cap back on - no more condensation. It's been a year since and no more condensation. :)
I had headlights on my BMW that used to condense up. BMW tried saying it was normal and within limits but in the end replaced them. No headlight was designed to condense up so they should be replaced.
Common on the e38 and e36, my e38 did this and my second e36, but weirdly, not my first, older higher mileage one???
My truck does this too, most of the '08 reg trucks at work have this issue, the remedy is a new headlamp unit from what Scania tell us.
Anyway, I cured the problem with my car by leaving the back cover off the headlamp during hot weather (such as now!) and the problem went away on both my e38 and current e36.
No doubt it'll be back at wintertime when it gets damp again, ultimately, its a new headlamp unit, easy when the company pays for them.....
Yeah we did and I had this problem on my Focus.
The way I fixed it on mine was to take off the bulb cap that is behind the headlamp and leave it off all day, if you want to get the job done much quicker then a hairdryer would do the job but as I was at work I didn't have access to a hairdryer so I just left the cap off for the whole 7 hours that I was at work and all of condensation had gone and I put the bulb cap back on. 2 weeks on now and the condensation hasn't returned *touch wood*.
Liam
why thank you mr lopez.
you didnt think that came out of my brain did you ?
nothing gets past you.
People generally credit their source when they copy and pase a big chunk of text.
We had a member here who used to make out he'd written lengthy tech posts when actually they were copied and pasted from other random sites.
I had it in the one of the front fogs on the festa, I just replaced the bulb and left the lights on.
If its like a swimming pool in there you have to get the water out because you just wont be able to burn it away.
If it comes back, then I think its time for a new unit.
My mate's Mulsanne had the same problem. We used a hairdryer to chase the water out.
Apparently the headlights have a breather hose that is worth checking that it is attached. It's also recommended to check the "seal" of the bulbs into the lamp unit itself (Hopefully that made sense?).
To do this will require the removal of the airbox which sits in front of each of the headlight units.. If it's the Driver's side then it isn't too difficult (undo the jubilee clip, remove the feed hose from the airbox, undo the clips, remove the airbox lid and filter), however if it's the passenger's side - Lord help you. You'll more than likely need to unbolt the main expansion tank, struggle like hell to get the clips off of the airbox, struggle like hell to get the airbox lid and filter out and then really, REALLY struggle like hell to get it all back in again - Seriously not fun.
APPARENTLY:
It is possible to get replacements on warranty, however first a "test" has to be done. The guys I spoke to couldn't remember what it is exactly, but it was something like driving the car around for a hour with the lights on, and if the condensation remained after this time then replacements can be fitted under warranty, if it has disappeared then it is seemed acceptable, and warranty won't pay.
Again, that is apparently, so please don't go around quoting that as gospel truth :)
Good Luck getting it sorted.
Go back to bentley and tell them if you wanted crap light condenstation you would have bought a cheap car not one that costs in the hundreds of thousands and demand they fix it. For free.
