- 12 May 2005
really?, what if its an announcement that nvidia are going bust?
Then I'm going to be first in line and say "Dudes - can I have your stuff?"
Engadget said:NVIDIA's GeForce GTX 460 hasn't even been officially announced, much less reviewed, but that won't keep you from buying the company's latest Fermi-based graphics card anyhow. Over at Newegg, usual suspects ASUS, EVGA, Gigabyte, MSI and Palit have fielded twelve models in all, most with slightly different features, thought it seems the base configuration has 336 CUDA cores (down from 352) and a mere 768MB of GDDR5 memory. Interestingly enough, this silicon's actually rated faster than its older brother the $280 GTX 465 with 675MHz graphics and 1,350MHz processor speeds, and a 3.6GHz effective memory clock. All your frames are pushed through a decidedly narrower 192-bit memory interface, though, so we'd guess that for around $200, you won't be getting (much) more than you pay for. Let's just hope they run cool.
Wonder what that $200 translates to in £GPU rates?
looks like a great mid-range card, and one which I would upgrade my HD5770. But the price is a tad too expensive for the 1gb version , and is in the HD5850 terrority.
in the OCuk shop now
768mb is £160 and the 1GB is £189-199
good competitive pricing
How do these fit into the big scale of things ATI compared graphic cardly?
Is it on par with a 5850?
So....is it likely to be relatively 8800'esque for fan noise? or another loud fermi?
Going to check out reviews now...
