Of course! It's network locked, not sim card locked!
Mines back on UK firmware now, as I needed to test a few things
So i'll re test![]()
Andy, do you rate the 020 UK Generic firmware over the rooted 023 version??
Do you find the incall volume on the 020 is slightly inferior to the 023 or is it just my ears![]()
are you using any Task Killers or auditors? thats good performance..............thinking of ditching mine to see what happens, whats your firmware rb020?
I personally don't rate any of the rooted versions because the battery life is shocking because the phone doesn't sleep correctly.
If you are running Generic UK Firmware and you do a OTA update, I have noticed you battery life isn't too good. However, if you update the handset via SUES to R2BA020 its much better
I am personally sticking with the Generic Nordic Firmware, which is R2BA023![]()
I think I may give the Nordic firmware a try then, as battery life is the most important to me...am currently on rooted 023.
Any guidence on how I can flash to the Nordic would be very much appreciated. Feel free to PM me if you don't want to clog up this thread![]()
My X10 Mini just arrived YAY, time to get my head around it
It says my android version is 1.6 is that up to date?
Correct![]()
What if you have both?![]()
clearly cross dress on wedensdays at the bingo halls.
anyone know if the guys who rooted are still working on the bootloader ? or did they just take the cash and flee !![]()
Here are my findings from OTA update VS SEUS update
Generic UK R1BA016 > OTA R2BA020 - Phone doesn't return to idle state correctly
Generic UK R1BA016 > OTA "Root" R2BA020 - Phone doesn't return to idle state correctly
Generic UK R1BA016 > OTA "Root"R2BA023 - Phone doesn't return to idle state correctly
All the above, I have found the phone not to sleep correctly and battery life because of this suffers.
Generic UK R1BA016 > SEUS R2BA020 - Phone sleeps correctly
Generic NCB R1FB001 > SEUS R2BA023 - Phone sleeps correctly
The updates by SEUS, seem to be a massive improvement over the OTA updates they are also much larger in size. This would suggest that a number of files are update unlike the OTA update.
Using the SEUS update I am able to get around 1 / 2 days from my phone now. However, using the OTA update I was lucky to get around 12/13 hours from my battery.
I hope you find this interesting.
