Did any of you guys used the original vertex tweak? I cloned my original SSD with installed tweaks and now i'm getting a freakish ATTO results.![]()
What on Earth did you do to get that?!
I used Both the OCZ Vertex tweak guide and tweak utility and since i just cloned my old SSD, the tweaks were copied over to the new Vertex 2. It seems i'm getting way faster speed than 6GB/s Crucial C300.![]()
I think i'm gonna implement the tweaks again. It certainly felt a bit snappier than the standard one.
Decided to get another one to try this Raid O hype and WOW! I'm impressed.
Are you impressed by the bench numbers or the actual real world performance?
Hi I got mine a few weeks back, finally got around to installing ahci and I have seen some performance increase, currently its in SATA port 5
How much extra performance would I gain if I moved it to SATA port 1?
Some screenies (because we love them):
Before IDE:
After AHCI:
Do a Secure Erase and re-install Windows using AHCI mode and use the first SATA port. Install iIntel IRST Driver and enable "Write caching" on the drive either through IRST app or through Device Manager.
